Coolant level?
Old Oct 25, 2011 | 01:33 PM
JerryB52's Avatar
JerryB52 is on a distinguished road
Arrow Coolant level?
Periodically I open the radiator cap to check the coolant level. The clear plastic coolant tank is useless.
It is always low when i check it, (can't see any coolant).
It never reads too hot according to the temp gauge.
My question, is this normal?
I don't see any leaks of any kind...
Thanks. JB
No, it is not normal for the coolant level to drop. That is an indication that you are loosing coolant somewhere. If you haven't ever replaced the radiator cap, I would do that first & foremost as it is solely responsible for maintaining pressure in a properly sealed system. You can also have your system pressure tested (or test it yourself) to check for leaks. If you apply 16psi to the system (cap rated pressure) and it slowly bleeds down to nothing, you have a leak.
Old Oct 25, 2011 | 06:01 PM
JerryB52's Avatar
I'll have to check it.
I'll Google and see what pops up.
Thanks.
Old Oct 25, 2011 | 10:47 PM
98blazin's Avatar
98blazin is on a distinguished road
if your coolant level gets low, and its not leaking anywhere, you must be burning it...
(intake manifold gaskets)
AcerDeucerQ
Dec 3, 2012 06:29 AM
Old Skool Soldier
Mar 29, 2011 06:44 AM
mearltobias
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Sep 19, 2010 04:06 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
2001blazer
Jan 30, 2006 10:45 AM
