cooler lines
Old Aug 29, 2011 | 09:34 PM
shawn51773's Avatar
shawn51773 is on a distinguished road
Default cooler lines
replaced the radiator in the blazer this weekend and the one i got has the jesus clip fittings into the radiator but the tranny has the flaired 3/8" nut on it. tried all the parts store and lowes etc and cant find the right fitting to switch it over on the radiator side.
does anyone know the chevy part number or where to get the fitting to switch it on the radiator side from the clips to the flaired nut?
thank and love the site so far a lot of usefull info!
Old Aug 29, 2011 | 09:35 PM
Can't you just remove the quick connect fitting from the radiator and thread in the flare nut?
Old Aug 29, 2011 | 09:58 PM
shawn51773's Avatar
the fitting in the radiator is 1/2" female and the fitting on my hardline from the tranny is a flaired 3/8" male. i just cant fine the fitting to reduce from 1/2" to 3/8" flair. i can cut the hard line and just use fuel line but cant get the corect thread size and count (1/2" 20")
Old Aug 29, 2011 | 10:13 PM
What are you working on? Did you get the proper radiator for your application?
So you need a 1/2" male inverted flare to a 3/8" female inverted flare fitting... Something like the Dorman 499-003 (box PN containing 10 parts) which is a 1/2-20 thread to a 3/8-24 thread and is a brake line fitting, but I'm not sure if it is appropriate for your application.
Or, something like the Dorman (Everbrass) 1739 which is a male 3/8" quick connect to a 3/8" female inverted flare connector.
Old Sep 9, 2011 | 03:02 AM
lucas30's Avatar
lucas30 is on a distinguished road
Can some body help me on how to remove the transmissions cooler lines please!!!
I need to change due to a leak in one line but i do not how far are in the transmission in how hard are to change.... Thank in advance for the help.
Old Sep 9, 2011 | 08:01 AM
shawn51773, how did you make out with your problem?
lucas30, depending on what you are driving, they could be threaded into the transmission or quick connect fittings. If it's a second gen, they will be quick connect where you may have to pull back a little plastic cover, then remove the 'e' clip from the fitting. Once the 'e' clip is out, the line can be pulled out.
Old Sep 11, 2011 | 11:25 PM
lucas30's Avatar
Thank you Swartlkk I belive my blazer it's second gen, is 01 blazer LT 4.3 vortec. I change the radiator before and I see the clip you taking about so they had "e" clip by the radiator and by the transmission. thank you so much for you input..
ComputerNerdBD
26
Nov 10, 2009 12:21 PM
splat
Dec 17, 2006 09:47 PM
Jetfixer
Jul 11, 2006 05:02 AM
eng69
Jan 31, 2006 04:55 PM
zero psi
Oct 28, 2005 04:45 PM
