CPI and CMFI--what's the difference??
Old Aug 7, 2007 | 10:20 PM
pinktruck's Avatar
pinktruck is an unknown quantity at this point
Default CPI and CMFI--what's the difference??
I'm trying to understand my engine.
Can someone please explain whether CPI and CMFI are two different things or not? The way I understand it, you would either have a central port injection system or a multi-point injection system--do I have that right, or am I missing something?? The reason I ask is that I have been told that my engine is CPI and also that it is CMFI. So, which is it, or is it both?
I have the 95 Blazer vin W. Thanks for any clarification.
Old Aug 8, 2007 | 09:17 AM
Default RE: CPI and CMFI--what's the difference??
It's been discussed before.
CPI (like '92-95' but unsure of first year used) == Central Port Injection --> The CPI system uses 1 electronic, batch fired fuel injector feeding 6 individual, pressure actuated poppet nozzles in the intake runner.
SCFI ('96-mid'02) == Sequential Central Fuel Injection --> The SCFI system uses 6 electronic, sequentially fired injectors located in a central injection body. Each electronic injector feeds 1 individual, pressure actuated poppet nozzles in the intake runner.
MFI (late'02-current) == Multiport Fuel Injection --> The MFI system is backwards compatible with the SCFI engines. Like the SCFI system, the MFI system has 6 sequentially fired, electronic fuel injectors, but these injectors are moved out to the intake runner, replacing the problematic poppet nozzles.
Hope that helps. So you're '95 is a CPI motor.
Old Aug 8, 2007 | 11:00 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Sweet, this helps me understand my engine now too, I was just decoding the VIN to find out what I had, from the other post you had. I thought I had MPI but I guess I have SCFI since I have a 98 with a W in the VIN position for engines. I assume that the SCFI is the one that has the fuel spider that seems to go bad every once in a while on some vehicles?
Old Aug 8, 2007 | 11:04 AM
Yeah, that VIN decode I posted isn't all that accurate... There's a lot missing.
Old Aug 9, 2007 | 03:54 PM
pinktruck's Avatar
That does help, and I don't mean to be a pest, but...my BIL insists I have central multi-point injection (CMFI)...could that be correct?? Also, on this webpage it says 95 had CMFI: http://www.answers.com/topic/chevrolet-s-10-blazer (scroll down about 2/3 to 1995 engines). I realize that answers.com is probably not the authority on engines, so certainly it could be wrong. But, I just have to ask.
I think it's the CPI that has the spider-thing that fails a lot.
Old Aug 9, 2007 | 05:33 PM
If by CMFI they mean central multi-point fuel injection then I guess that is sorta correct. However, typically, MFI is an acronym to describe sequential multi-point systems and not the single injector, batch fired system that is the CPI.
prbjeepin
Apr 8, 2013 10:14 PM
blazerman9497
Jan 15, 2010 08:50 AM
92ChevyBlazer
Aug 6, 2006 03:59 PM
jaykeMURD
Jun 22, 2006 08:13 PM
Mr. Chevy
Apr 21, 2006 11:46 AM
