cpi to tbi
Old 09-28-2007, 03:13 PM
Default RE: cpi to tbi
Yes, to your '95 motor, they should be the same. Please put your vehicle information in your signature and attach it to your posts so questions can get answered more clearly.
Old 09-29-2007, 08:56 PM
SirLDragon is an unknown quantity at this point
ORIGINAL: Hanr3
That answer depends on the year of the truck, not the CPI/TBI/fuel injection system.
In '95 GM changed the angle between the heads and intake manifold. Intakesprior to '95 can be swapped on engines prior to '95. Intakes after '95 can be swapped on engines after '95. You cannot swap intakes prior to '95 on engines after '95 and vice versa. That is hte simplified version.
Ok, that's completely off from what I've been told prior to this. And kind of confusing since the CPI ("W" code Vortec) intake is the same from '92 to '95. Or is there a difference to the inside of the lower plenum where the bolts are?
Old 09-30-2007, 12:08 AM
Hanr3's Avatar
This may help.
http://www.babcox.com/editorial/ar/ar40047.htm
'95 is a confusing year. GM made changes over the life of the engine, however '95 is the most confusing.
deathman
08-14-2011 11:25 PM
maverik78
Performance & Brainstorming
04-11-2010 10:05 PM
andrewhartley55
13
11-30-2009 12:54 PM
chrisw1022
11-17-2009 09:34 PM
dbleon
01-25-2008 06:54 AM
Quick Reply: cpi to tbi
