Crackshaft oil seal
Old Oct 30, 2012 | 10:43 PM
Roberto Lavin Lopez's Avatar
Roberto Lavin Lopez is on a distinguished road
Default Crackshaft oil seal
QUick question: I have a Blazer 1999 and today get a huge oil leakage trought the crankshaft oil seal. I need to just replace the seal or the entire timing chain cover? (haynes recommend says the latter)
Also: rear and font seals fails at the same time?. It is necessary to change both seals?
Old Oct 30, 2012 | 11:49 PM
abig84's Avatar
the front seal is pressed into the timing cover. you can just pop that one out and replace it. the back is a way bigger job if its not leaking leave it alone. you will need to remove your transmission and flexplate to get at it.
out of all the stuff ive done on chevys ive never had one go bad in the vehicle. when rebuilding engines i have changed them with the timing cover off which makes it really easy. so i dont know how much of a pain its going to be to pop it off with the crank coming out of it. try searching on youtube and see if someone has a how-to vid on it
latunguley
Nov 17, 2014 09:15 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
litterbug
Mar 7, 2011 09:14 PM
Mr.T
Nov 2, 2010 06:26 PM
MikeD
Engine & Internal
Mar 3, 2007 11:24 PM
