Cranks but will not start
Old Jul 18, 2011 | 08:58 AM
wbostel's Avatar
wbostel is on a distinguished road
Default Cranks but will not start
This is for a 99 blazer 4.3. The replacement engine was a 2001.
After an engine swap the replacement engine will not start.
Here is what was done.
The replacement engine had all of the gaskets replaced, we did remove the
distributor when the intake manifold was removed.
The knox sensor was moved from the old engine.
The engine cranks, but will not start.
What has been checked.
1) have fuel pressure at the intake.
2) have spark
3) have oil pressure
4) have check the timing
5) have sprayed intake cleaner into the intake and the engine will fire
6) No codes
Any thoughts no what I am missing........
Thanks
Old Jul 18, 2011 | 10:25 AM
hertz20's Avatar
hertz20 is on a distinguished road
Do you have injector voltage pulse while your tring to start it?
Old Jul 18, 2011 | 10:35 AM
Are all of the fuses good?
What was the fuel pressure with the key-on/engine-off? Did it exceed 55psi? Did it remain above 50psi for 10 minutes after the pump shut off?
Have you read either of these two DIY articles?
Engine Cranks But Does Not Run
No-Start - Engine Cranks OK - Ignition System Diagnosis
Old Jul 18, 2011 | 11:34 AM
wbostel's Avatar
hertz20
Yes.
swartlkk
Are all of the fuses good? Yes
I see 50 PSI when the key is on/engine-off. And yes it keeps the 50 psi after the key is turned off.
Old Jul 18, 2011 | 12:11 PM
50psi is not high enough for these engines. The lowest I have seen from a running engine on an accurate gauge is 55psi. GM states 60psi as the proper low limit.
Sounds like the fuel pump is weak.
Old Jul 18, 2011 | 12:38 PM
wbostel's Avatar
Just replaced it last year. I will have to recheck when I get home.
Old Jul 18, 2011 | 03:08 PM
wbostel's Avatar
I had some time and checked it and its at 62 psi.
Old Jul 19, 2011 | 07:34 AM
wbostel's Avatar
Any thoughts on this. When I pull the #1 plug to check for TDC.
The plug does not have any gas smell.
Should I smell gas after tring to start it?
Old Jul 28, 2011 | 09:21 PM
wbostel's Avatar
I found my problem. It was the spider. Put the one in from the old engine.
Boiler_81
Oct 30, 2011 05:01 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
TourRider
Jan 7, 2008 11:17 AM
