cranks like out of time
Old Jul 16, 2012 | 04:15 PM
busted knuckle's Avatar
busted knuckle is on a distinguished road
Default cranks like out of time
i have a 2001 blazer 4.3 or rather my wife does a couple months ago it started running rough so considering the milage a tuneup was in order so i did a complete tuneup cap rotor good plugs fuel & air filter oil change everything but wires it needed the tuneup but running did not improve number 5 plug had corrosion that hinted to a blown head gasket changed those then started having a hard crank problem as if it were out of time i know it was right but when i put it 180 out it tries to start and of course backfires through the intake with its high milage i thought a timing set may be needed did that yesterday it was worn but not that bad i did do a fuel port test got 62 lbs initially and back bleed to 55 i did not do a max test at the filter i am going to put a fresh battery in it sense these trucks require a lot of power to get started i know its a long post but we are getting desperate and cant afford a shop man i wish i could.
any help will be so very appreciated
Old Jul 19, 2012 | 05:50 PM
Wink time for the shop
well im pretty sure this thing needs a starter even with a new hot battery and jumpers it barely cranks thenk cranks good a few times then drags again plus 99% positive it needs a fuel pressure regulator with my regular job and honeydo's i just dont have the time nor the proper tools my wifes gonna love this bill lol.
Old Jul 19, 2012 | 06:46 PM
bajablazer93's Avatar
bajablazer93 is an unknown quantity at this point
I wish the best of luck to you. It sometimes feels like a never ending battle just trying to find solutions to problems. my dad has a 2000 s10 and it started running really really bad. But it was just that he needed to use his ac. Maybe it was about to sieze up im not too sure. Is the check engine light coming on?
Old Jul 23, 2012 | 05:05 PM
we took it to a shop it was still out of time and my son cracked number 5 plug and it needed plug wires nothing major but it was $505.00 but it runs now and she's happy.
kwbond
Mar 18, 2014 12:39 AM
bsbob
Jul 22, 2011 12:48 PM
1djcarlos
Jan 15, 2011 03:46 PM
77Nova
Aug 28, 2010 10:38 AM
nyjeepman
34
Mar 15, 2009 07:40 PM
