1997 Blazer Oil Leak
Old Jul 19, 2012 | 09:58 PM
cloudchaos's Avatar
cloudchaos is on a distinguished road
Default 1997 Blazer Oil Leak
I just bought my 97 blazer and it was leaking oil from what looked like the oil lines so i replaced them all (230000 miles on the truck). now the front is dry but i am still dripping oil while the engine is running on the left (driver) side of the engine bay. could this be a oil pressure sender or a seal.
Old Jul 19, 2012 | 10:04 PM
cucv30's Avatar
cucv30 is on a distinguished road
it could be but it also could be coming from the adapter o ring where your lines connect at the back of the block.
Old Jul 20, 2012 | 12:00 PM
cloudchaos's Avatar
I had all the lines changed and from the block to the remote housing and to the radiator and they changed the quick release fittings as well would that o ring have been replaced then or not
Old Jul 20, 2012 | 12:16 PM
NCSurvival's Avatar
NCSurvival is on a distinguished road
check all the valve covers? The only place on drivers side that I could think of is the adapter lines to the block. Make sure your rear main isn't dripping from the weep hole on the torque converter cover as well....
Old Jul 21, 2012 | 11:10 AM
NCSurvival's Avatar
Alot of times, if the adapter to the block is not put back just so, or, old o rings were reused, or if the bolts were not tightened properly, it will leak.
Old Jul 21, 2012 | 07:43 PM
cucv30's Avatar
I would say they probably weren't cause you can change the lines without removing the adapter. You might ask them and see if they changed them.
Old Jul 24, 2012 | 08:26 PM
cloudchaos's Avatar
the aftermaket seal they got was to thick they got a new one from the dealer now its is only leaking a little they think it my be the housing. The guy that owns the shop is looking at it tomorrow. I dropped the car off at his house and he is going to take care of that and the transfer case not fully disengaging on the passenger side one of the two switches is bad and he is replacing both for me.
userID-81055
Apr 4, 2015 08:21 AM
userID-81055
13
Apr 6, 2014 06:32 PM
ComputerNerdBD
Mar 20, 2013 12:33 AM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
