crankshaft positioner
Old Jan 24, 2010 | 03:57 PM
coupedeville59's Avatar
coupedeville59 is on a distinguished road
Default crankshaft positioner
having issues cranking 97 blazer when it is raining outside. It will turn over but not crank. When it is dry I only have slight issues. Doing research it looks like I need to replace the crankshaft positioner. Where is it located and how to you replace it?
Old Jan 24, 2010 | 04:17 PM
rriddle3's Avatar
This situation is more commonly associated with the distributor cap. Check it for cracks, carbon tracing, or being loose. I don't know about the '97s, but on some model years there is a small screen on the base plate of the distributor that can get debris on it and moisture will collect there, causing issues.
johnbrown06
Nov 26, 2009 05:16 PM
agent305
Jun 10, 2008 02:56 PM
murfthesurf4
Nov 26, 2007 11:54 AM
Swain
Sep 7, 2007 12:11 PM
KA3AX
17
Apr 20, 2006 01:11 AM
