csefi supply/return lines
Old Feb 10, 2009 | 08:14 PM
jon_beeker2000's Avatar
jon_beeker2000 is an unknown quantity at this point
Default csefi supply/return lines
I have a 2000 blazer with CSEFI and I removed the unit to replace the intake manifold gasket. Upon reassembly, I cannot reattach the fuel supply/return lines. It looks like there is an oring sideways in the larger hole (return?). I cannot move this ring. Any suggestions? Any help will be greatly appreciated!
Old Feb 10, 2009 | 10:20 PM
Default RE: csefi supply/return lines
You did not just bend the lines back did you?
You need to pull out the spacers and o-rings and make sure they are positioned properly. If you sliced an o-ring, you have to get the o-ring kit which is universal for all SCFI motors and includes enough o-rings to completely re-do a v8 spider.
The illustration below shows the proper order of the components:
Brookhaven
Aug 26, 2015 12:52 PM
Catfishguy
Dec 2, 2013 01:17 PM
CSTelfer
Sep 15, 2011 04:42 PM
clone432
15
Sep 28, 2009 06:36 PM
36ford7
Nov 11, 2008 10:15 AM
