The "cushion" around shifter shaft between top of tranny and body...
Old Aug 11, 2020 | 09:25 PM
BlazerDog97S10's Avatar
Exclamation The "cushion" around shifter shaft between top of tranny and body...
Howdy...
Hoping I can get some help in locating a new one of these. I can't find a replacement for this. I don't even know what it's called to be honest. Cushion....dampender...seal...idk how to refer to it so I'm not getting accurate web results. It goes around the stick shift on top the manual transmission out of a 97 base model 2 door 4x4. What is the correct name for it so i can locate a replacement.
Much obliged ahead of time...
Old Aug 13, 2020 | 05:24 PM
daveca's Avatar
Typically called a shifter boot...
Old Aug 14, 2020 | 03:40 PM
Well...I know enough to know it's NOT a shifter boot. This is underneath around the shifter on top of the transmission; NOT around the shifter in the cab.
And upon doing more research I found that it's a "foam insulator"; still which I can't find any sort of replacement for. Reckon I'll just use the old one.
Luthor
Jul 11, 2017 07:25 PM
socalmasterschamp2001
Jul 11, 2015 05:58 PM
Black n Chrome
Jan 23, 2010 01:42 PM
buggyblazer
14
Dec 23, 2008 08:22 PM
xtreme03
Engine & Internal
Sep 30, 2006 06:25 PM
