Cylinder head interchangeablilty questions
Old Aug 31, 2016 | 09:09 AM
Baxter1's Avatar
Baxter1 is on a distinguished road
Default Cylinder head interchangeablilty questions
Well I'm at it again. I searched and searched and maybe I'm terrible at searching but I didn't come up with anything.
Long story short. I have an '02 that blew a head gasket. Yanked the cylinder head to find it cracked. I have sitting on the floor an engine from a '98. Yanked it's head off, it's in great shape.
BUT! As far as I can tell, the only differences are-
(1)- Casting numbers
(2)- Rocker arms. The newer engine has bolt down rocker arms, the old one has a stud with a nut. Is there any reason they wouldn't be interchangeable? The pushrods and what-not are the same length.
According to O'reilly's website, the valves are the same, the head gaskets are the same.
SO! Can I just swap 'em over or what?
Thanks guys.
Old Aug 31, 2016 | 03:08 PM
LesMyer's Avatar
Thanks guys.
Use the 1998 rockers on the 1998 heads. Pushrods and Lifters are the same part number between the two years.
Old Sep 15, 2016 | 09:52 AM
Baxter1's Avatar
Well that's exactly what I did and it worked great!
Now I just need to see how badly this frame is bent...
Old Sep 15, 2016 | 02:18 PM
LesMyer's Avatar
glad it worked out for you. Thanks for letting us know.
echo1
Aug 10, 2012 11:36 PM
kaynos
Aug 11, 2011 03:01 PM
mbar
Nov 10, 2010 02:39 PM
Paul96blazer
May 8, 2008 09:27 PM
zeb_ford
Jan 3, 2008 11:34 AM
