Delayed Engagement?
Old Jun 2, 2018 | 05:45 PM
peenar's Avatar
peenar is on a distinguished road
Default Delayed Engagement?
im pretty sure I have Delayed Engagement. I put it in gear and it takes a couple of seconds to engage.
also when reversing it tends to be a lil more hesitant to go backwards, when it does go backwards it can sometimes make a bit of noise. It goes forward and accelerates just fine.
Old Jun 3, 2018 | 04:21 AM
Transman304's Avatar
Check the fluid level and condition. The backing up and noise may be the issue as that is a common complaint when the rear planetary gears are failing. How many miles on the vehicle?
Old Jun 5, 2018 | 04:14 PM
peenar's Avatar
its got like 200k+ and was parked for like 6 months over the winter.
I checked fluids and topped oil up before attempting to fire it up. ran a lil rough at first but seems to run like it did before it was parked.
Old Jun 5, 2018 | 07:15 PM
Do you have rust on the brake rotors? Rust in the rear drums?
Old Jun 5, 2018 | 07:23 PM
peenar's Avatar
Yes the obvious rust on the rotors. Probably on the drums. It rolled backwards downhill no problem. After having the ebrake on for the 6 months it was parked.
Old Jun 5, 2018 | 09:31 PM
I would look at other areas before heading in the direction of transmission. Good luck
rsz28
Feb 13, 2015 12:42 PM
jzalabowski
Mar 3, 2010 09:36 PM
2005Jimmy
Feb 14, 2010 12:58 PM
edsnie77
Oct 27, 2009 02:32 PM
dart08
Sep 24, 2009 04:56 PM
