Desperate
Old Sep 7, 2012 | 07:34 PM
pantealeo's Avatar
pantealeo is on a distinguished road
Default Desperate
I have a really bad problem with my 89 Blazer.It started gradually while accelerating now it doesn't accelerate at all.,it won't even start unless I floor the gas pedal and then it will make this hoarse wind rushing sound...
Old Sep 9, 2012 | 12:06 PM
matthewp's Avatar
matthewp is on a distinguished road
Could be an EGR valve problem. See where the EGR pipe goes into the intake manifold, unbolt the EGR pipe from manifold, and block it with something solid so you don't have an intake leak. If starts up with no problems just replace the EGR valve.
Old Sep 9, 2012 | 12:16 PM
pantealeo's Avatar
Default Nothing doin'
I've already done that,but it stays the same,thx...
Old Sep 9, 2012 | 12:19 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
i would check your fuel pressure. I would also listen for vacuum leaks, will it idle after you start it?
Old Sep 9, 2012 | 12:28 PM
pantealeo's Avatar
It was idling well,now it won't stay on i've already plugged all the vacuum lines and still the same,how(where) do I check the fuel press....
Old Sep 9, 2012 | 07:24 PM
chris015's Avatar
sounds like the pump. Try spraying some ether in the throttle body and try to start it without pressing the gas. does it start right up and die? if so its probably the pump.
Old Sep 9, 2012 | 09:49 PM
4.3L with throttle body injection? Two fuel injectors visible when you remove the air cleaner? Exhaust restriction? Possible catalytic converter restricted? Remove the oxygen sensor and see if that makes a difference, (other than noise)
Old Sep 9, 2012 | 11:58 PM
pantealeo's Avatar
Thanks guys I'll look into that later,I'm kinda busy y'know. I'll let you know what developes when I get to it...
lowloudnproud1
Jun 13, 2010 01:34 AM
PINK JUNK
Mar 21, 2010 02:39 PM
Al3x
Mar 7, 2010 09:49 PM
blkblazer
Aug 30, 2009 01:59 PM
BlazinMike89
Jul 6, 2009 08:03 PM
