Desperate, broke and not that mechanically inclined :/
Old Jan 4, 2012 | 03:57 PM
chris015's Avatar
Suprised nobody else has noticed you put 3.1 v6..
You have a 4.3 v6. thats all the early 2nd gen blazers came with.
Old Jan 4, 2012 | 05:52 PM
TheRandom1's Avatar
Yeah, I meant to mention that too, but apparently left that bit out. Whoops.
Old Jan 5, 2012 | 03:32 AM
Michael Starkey's Avatar
Michael Starkey is on a distinguished road
Good to know for future reference. And probably something I should have known. Thanks.
Old Jan 10, 2012 | 08:05 AM
So an update:
After going through the suggestions, and starting with taking out the Thermostat, we discovered that it was Frozen shut. So that solved the overheating issue. We flushed the system till it ran clear, but have not put in the Flush cleaner yet. I'm going to run it till saturday with just water and antifreeze to see if more of that gunk gets knocked loose.
Then I'm going to drain it, flush it, drain it again, and use the flush cleaner(couldnt get Peak, az was all out, but I did get some flush cleaner). then drain it again and fill with coolant and water.
Again, thank you everybody!
Old Jan 10, 2012 | 08:30 AM
warthogdriver's Avatar
Good to hear..one down one to go...good luck
lowloudnproud1
Jun 13, 2010 01:34 AM
PINK JUNK
Mar 21, 2010 02:39 PM
Al3x
Mar 7, 2010 09:49 PM
blkblazer
Aug 30, 2009 01:59 PM
BlazinMike89
Jul 6, 2009 08:03 PM
