Difference in a truck 5 speed and s10 5 speed
Old Jul 21, 2013 | 10:36 PM
jdub9000's Avatar
jdub9000 is on a distinguished road
Default Difference in a truck 5 speed and s10 5 speed
hey guys been a LONG time since I have been on here... my next endeavor on the old blazer is a 5 speed swap....so I went to my local pick-n-pull salvage and I can get ANY trans for $90 ... didn't find one from a blazer but I did find one in a half ton 4x4.... anybody know if the dimensions are close or same? and is the transfer case bolt pattern the same?
Old Jul 22, 2013 | 07:58 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
demensions may be longer depending on the trans, there where a few different ones thru the years. the transfer case pattern should be the same. The length is going to be different than the automatic no matter what way you look at it. What are you going from and you need to figure which manual trans your getting. Or just get under there and measure, that's always the sure fire way
chexoe
Aug 3, 2008 06:04 PM
bitbandit
Tires and Wheels
Feb 12, 2008 02:41 PM
pinktruck
Aug 9, 2007 05:33 PM
nofear17bmx
Aug 3, 2007 11:24 PM
Pugsley
Feb 2, 2006 10:08 AM
