Differneces between the VIN W and VIN Z 4.3
Old Oct 18, 2009 | 09:04 AM
SlydinClyde's Avatar
SlydinClyde is on a distinguished road
Default Differneces between the VIN W and VIN Z 4.3
Looking to rebuild my 4.3 Vin w on a 94 Blazer 4X4 and was wondering if there was a differnece between the internal parts on the VIN W & Z. I know one is TBI I believe is that the only difference?
Old Oct 18, 2009 | 01:09 PM
ABN31B's Avatar
______LE8_____8 cyl. 7.4L (454 c.i.d.)
W
______L35_____6 cyl. 4.3L (262 c.i.d.) CPI
OR
______LF9_____8 cyl. 5.7L (350 c.i.d.) diesel
Z
______?_______? cyl. 4.3L (263 c.i.d.) EFI
* i think Z swings both ways. It should be a 6 cyl. BUT if you get it drunk enough...
Hope that helps some.
Old Oct 18, 2009 | 05:39 PM
The cam will be different due to the different induction setups. The heads should be almost the same. You may want too look at how all of the accessories mount up because there may be differences there as well.
Do a google search for Rebuilding the 262 by Doug Anderson (or is it Andersen?) and read it all. That article is great for information on the early 4.3L v6.
Old Oct 18, 2009 | 08:14 PM
I will look at that post thanks.
I am just looking for the Main, Rod cam bearing and rings so i am guessing it will work ok will research and post back with the info.
93S10TahoeLT
Apr 5, 2013 06:59 PM
hardyboy
Mar 23, 2011 08:04 PM
BlazerSS
Engine & Internal
Apr 21, 2007 03:44 PM
4WD Rookie
Mar 6, 2006 10:41 PM
Pugsley
Feb 2, 2006 10:08 AM
