Dist. or coil trouble..I think?
Old Oct 22, 2010 | 05:47 PM
65longroof's Avatar
65longroof is an unknown quantity at this point
Default Dist. or coil trouble..I think?
Ok here is what the truck is doing, oh it's a 95 S-Blazer with 183,000 miles. It seems to have a huge lack of power anywhere below 3,000 rpm's. I was thinking it could be the coil going bad, the ICM not advancing properly or the coil is getting weak. I'm I on the right track or shoud I be looking else where?
Thank you,
Paul
Old Oct 24, 2010 | 09:13 PM
Farmboy92's Avatar
Farmboy92 is on a distinguished road
I have the same blazer, with the same problem. It gets even worse when accelerating fast, mine bogs down real bad, i have no clue whats wrong
Old Oct 25, 2010 | 04:21 PM
nogi's Avatar
nogi is on a distinguished road
try cleaning your mass air flow sensor gotta take it apart to get at the wire and may have to pick some grime off of it i used a pick and becareful they get pricy i did the full tune up wires, plugs, cap, coil, rotor, fuel filter, and it was still doing it so i mess around with my mass air flow sensor and now i have a new truck
ps i also changed cat and no differance before mass air flow
Old Oct 26, 2010 | 04:11 PM
65longroof's Avatar
I didn't think the CPI engines had mass air sensors. I know they have an intake air temp sensor, throttle position sensor and idle air control valve. Am I just missing it? Thank you.
Old Oct 31, 2010 | 07:57 AM
shane216's Avatar
shane216 is on a distinguished road
maybe your converter is clogged up. does the exhaust smell like rotten eggs?
Old Oct 31, 2010 | 10:15 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
my 95 does not have a mass air sensor either......you dhould check your basic tune up parts first. then do a fuel pressure test to see if its with spec of 58 psi or more....also check to see if any vacuum lines are broken or dry rotted. does your radiator come up low every so often?
Old Oct 31, 2010 | 01:06 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
It could be any of those things mentioned above. But if it is the catalytic converter and easy way to check is hook up a vacuum gauge, start up your blazer and rev the throttle by hand. If the vacuum goes up real fast but goes down slowly then it is most likely the cat. Also if it was the coil or dist I'm pretty sure it would bog down at all speeds.
Old Aug 16, 2011 | 08:35 PM
65longroof's Avatar
The cat was replaced before I bought the truck. I will have to check it with the vaccuum gauge anyway just to be sure. There is no rotten egg smell. It has also started stumbling, almost like a miss on lighter excelleration and sometimes during steady driving speed. The fuel pump is new and I have done the full tune up recently. The only thing not stock is that I have a fresh air intake and a turbo muffler.
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
scott96
May 26, 2008 09:21 PM
fnirish
Oct 24, 2006 02:02 AM
