Distributor problems
Are you using the correct weight of oil? Supposed to be 5W30. Thicker oil can cause excessive wear on the distributor gear.
Along with what others have asked/suggested, what brand of distributors have you been using?
Have you set the CMP Retard appropriately when installing each new distributor? CMP Retard is a scan tool PID that correlates to the proper alignment of the distributor to the cam which, when set appropriately, will lead to the best distributor gear life.
LesMyer
18
May 16, 2016 06:04 AM
ballparkfm
Feb 7, 2013 04:37 PM
Klturi421
Aug 5, 2012 07:59 PM
Nutty 99 Blazer
Apr 2, 2010 08:50 AM
