Does your s10 jerk/buck at steady speed/rpm, let's fix this togheter!
Old Jul 25, 2010 | 11:02 PM
  #21
bulletuga's Avatar
bulletuga is on a distinguished road
mine doing the same thing i just replace the intake gasket and now it do the bumping and jurking at stedy speeds it did not do this before i changed the intak gasket
Old Aug 29, 2010 | 06:53 PM
  #22
Sleazy_E's Avatar
Sleazy_E is on a distinguished road
Would your solution on replacing the fuel pump and cat work on 1991 Blazer with 4.3 TBI? I have the same issues of a rough idle at stop lights, but I think mine also has a drop in oil pressure.
I changed my cat about 4 years ago (I don't know what normal maintenance on that is). I'm sure I've changed my fuel pump on this in the last 5 years of ownership, but I'm not sure what the garage I took it to used for a replacement.
Old Aug 29, 2010 | 10:06 PM
  #23
BresBlazy's Avatar
BresBlazy will become famous soon enough
Mine was doing that only at 2500 rps and under 30mph and if its cold....I changed out my injector, it worked great for the first few days, then started up again, was told to try cleaning the MAF sensor, I did that and it seems to have helped....ALTHOUGH some times when I turn the car on it says I have no gas and my gas light is on, then other times its full when it is NOT full....just in the last week, Im wondering if this IS my fuel pump, going to try replacing cap and rotor and some other things RATS.
Glad you got yours working again!
Old Oct 13, 2010 | 01:07 AM
  #24
RIFLEMAN 308's Avatar
RIFLEMAN 308 is on a distinguished road
I think everybody should check out my thread labeled FOUND MY PROBLEM!!!!! and read it all the way to the end because I cured ALL of my bucking and jerking forever by cleaning and relocating splice pack sp423 and new ignition parts plugs,wires,cap, and rotor, but the big culprit was sp423!!!
Old Oct 13, 2010 | 01:04 PM
  #25
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
can you post the link to your tread ?
Old Oct 13, 2010 | 01:33 PM
  #26
A search for "sp423" with an author of "RIFLEMAN" will return the thread.
maverick_4x4
Engine & Internal
15
Nov 8, 2015 12:44 PM
CAB
Dec 4, 2013 10:54 AM
R.Daughtery
Sep 29, 2013 02:31 PM
vagnozzi
Headers, Intake, & Exhaust
Jun 28, 2007 02:52 PM
gmyoyo
Nov 7, 2005 02:42 AM
