Drain trans without dropping pan?
Old Mar 12, 2012 | 04:30 PM
6Cyl'erThriller's Avatar
6Cyl'erThriller is on a distinguished road
Default Drain trans without dropping pan?
I want to add some Lucas trans treatment but I don't want to drop the pan. What are my options?
Old Mar 12, 2012 | 04:35 PM
pettyfog's Avatar
Find the Trans cooling line FROM trans into radiator, usually the upper if I remember, slide tight fit tubing over it, pump out a pint.
Old Mar 12, 2012 | 05:25 PM
Pump? How Exactly? Just run it thru the gears?
Old Mar 12, 2012 | 05:56 PM
pettyfog's Avatar
Try it in park and find out.
Old Mar 12, 2012 | 06:07 PM
I'm not even 100% sure which fitting it is. I think its the small fitting on the top right if your looking at it. I've never used this method before. thanks for the reply
Old Mar 12, 2012 | 09:22 PM
bobby099's Avatar
bobby099 is on a distinguished road
The cooler line is right by the radiator. Just unscrew it and start the truck have someone start it and it will pump out it only will take 30 seconds then put the line back together than add the lucas to it and drive it for a few.
Old Mar 12, 2012 | 10:22 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
You can always follow the lines and see where they go. But you will either get oil or transmission fluid when you take the line off.
Old Mar 12, 2012 | 10:48 PM
xgiovannix12's Avatar
oil lines are on the driver side trans lines are on the passenger side
correct me if im wrong
Old Mar 13, 2012 | 01:05 PM
neo71665's Avatar
Unless some major design changes have went on that's pretty universal.
Sullivan
Feb 16, 2012 04:56 PM
kennybopaloo
Apr 21, 2010 06:30 AM
taba5
Dec 7, 2009 06:27 AM
TAZ454
Feb 1, 2008 02:57 AM
