Driveline noise
Old Oct 22, 2019 | 12:03 PM
berger8891's Avatar
berger8891 is on a distinguished road
Default Driveline noise
Hey. I’m new here so hopefully everything goes well. I have a 2005 2door and I have a bad humming noise... it’s not a wheel bearing and it’s not my rear bearings as I just replaced them with speedy sleeves. I changed the diff fluid and checked the rear end and it all looked okay, and I changed the rear ujoint on the rear driveshaft. If I jack the rear up and run it in drive, I can hear the noise. And when driving it sounds like I’m the centre of the truck. I checked the transfer case fluid and it’s bright red. Same with the trans fluid. I can’t find the issue!
it seems to happen only when on the gas. If I put it in neutral it quiets down and it quiets down she the transmission shifts.
please help!!!
Old Oct 22, 2019 | 02:11 PM
Sounds like possibly a bad pinion bearing. With the truck jacked up and parking brake released, disconnect the driveshaft from the pinion yoke and rotate the yoke slowly by hand. If it feels crunchy, it's bad.
Old Oct 22, 2019 | 05:03 PM
berger8891's Avatar
cool thanks Tom. I’ll take a look tomorrow! Thanks.
01blazer4.3p
Dec 4, 2011 10:02 PM
2005Jimmy
Feb 14, 2010 12:58 PM
jonnyisback
Sep 15, 2009 05:02 PM
norman_mckenzie
May 8, 2007 05:16 AM
oldchevron62
Nov 27, 2006 12:54 PM
