Driver side valve cover gasket
Old Aug 19, 2009 | 03:56 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Driver side valve cover gasket
It looks like my drivers side valve cover gasket leaks and I wanna replace it. The only thing I'm not sure of is how to get the cover up and out of that tight spot it sits in? On the front you have the steering pump/alternator bracket and on the back there's the brake booster. Its those 2 thing that I can see getting in the way of removing the valve cover. Is it necessary to remove that front bracket, in which I'll need a p/s pump pulley puller so I can get to the bolts that sit behind the pump? Any one ever done this job on a cpi motor?
Old Aug 19, 2009 | 04:07 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Its a pain but can be done with patience..You may find it easier to pull the wiring harness out of the way on that side...It will wiggle outta there without pulling brackets.
mamawolf70
Apr 10, 2020 10:44 AM
marksoftball
Nov 29, 2014 09:27 PM
89Recon
Oct 22, 2011 05:50 PM
mladsig
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 1, 2010 05:35 PM
darkshines
Sep 25, 2008 06:53 PM
