Idle problem
Old Aug 19, 2009 | 12:50 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default Idle problem
Since I put the motor/wiring/trans/etc from my 97 into my 95 it has idled strange. When you start it there is no prob. but after you drive it and put it in neutral the engine will idle up to 2k then slowly drop, then raise to 1800, then drop, then raise to 1600, then drop(takes about 1min before it settles on 1k).
I have spraid every vacuum line and the intake with carb cleaner trying to find a leak but nothing.
Old Aug 19, 2009 | 02:53 PM
rriddle3's Avatar
Sounds like the idle air control (IAC) needs cleaning or replacing.
Old Aug 19, 2009 | 03:54 PM
blazin97's Avatar
I cleaned it about a month ago. Shouldnt it send a code for the iac?
Old Aug 20, 2009 | 06:25 AM
Katmandu's Avatar
Katmandu is on a distinguished road
Arrow
Readjust the TPS (Throttle Positioning Sensor).
Old Aug 20, 2009 | 07:35 AM
blazin97's Avatar
how do you readjust the tps? I thought they werent adjustable.
It idles down after a minute, and the tps has full sweep from .5v to 5v(I tested it with a scanner), so wouldnt that say the tps is working right?
blazer chris
Dec 8, 2011 09:56 AM
UnknownFish
22
Nov 14, 2011 07:40 AM
Chevrolet.Love
Aug 19, 2011 09:05 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
Daytripper540
Mar 29, 2007 03:54 PM
