Drivers side valve cover
I have an 87 Blazer with a swapped 400 in it, and I pulled off the drivers side valve cover for the first time today and found this nasty light brown colored sludge all around the oil filler hole. Is this something I can fix?
Thanks
Thanks
Could be regular old sludge which will dissipate over time using good oils, or it could be coolant contamination. How did the underside of the valve covers look? If they too had sludge droplets on them, then you may want to consider a good engine flush.
The passengers side valve cover was clean as can be, but teh drivers side only towards the front (oil fill hole), was covered in sludge, both on the valves and the inside of the valve cover. Prolly a good handful of sludge. But all the sludge was in a 3 inch area, the rest of the area was clean.
marksoftball
Nov 29, 2014 09:27 PM
89Recon
Oct 22, 2011 05:50 PM
Wexinlo
Apr 6, 2011 11:35 PM
Tony H
Jun 14, 2009 10:32 AM
