Drivers side valve cover
Old May 5, 2010 | 11:53 AM
dothedeww's Avatar
dothedeww is on a distinguished road
Default Drivers side valve cover
I have an 87 Blazer with a swapped 400 in it, and I pulled off the drivers side valve cover for the first time today and found this nasty light brown colored sludge all around the oil filler hole. Is this something I can fix?
Thanks
Old May 5, 2010 | 12:01 PM
Could be regular old sludge which will dissipate over time using good oils, or it could be coolant contamination. How did the underside of the valve covers look? If they too had sludge droplets on them, then you may want to consider a good engine flush.
Old May 5, 2010 | 12:10 PM
dothedeww's Avatar
The passengers side valve cover was clean as can be, but teh drivers side only towards the front (oil fill hole), was covered in sludge, both on the valves and the inside of the valve cover. Prolly a good handful of sludge. But all the sludge was in a 3 inch area, the rest of the area was clean.
Old May 5, 2010 | 12:24 PM
Does the engine have a functioning PCV system?
Old May 5, 2010 | 12:52 PM
dothedeww's Avatar
Honestly I dont have a clue...how can I check that? I wouldn't even know where to begin to check that.
Old May 5, 2010 | 01:13 PM
Do you just have breathers on the valve covers or do you have a hose that runs into either the carb or the intake from the valve cover?
Old May 5, 2010 | 01:14 PM
dothedeww's Avatar
It has breathers
Old May 5, 2010 | 01:16 PM
It is possible that the 'sludge' isn't really sludge, but a sort of aerosolized oil goop that has coagulated under a breather and will not present any problem with the operation of the engine.
Old May 5, 2010 | 01:31 PM
dothedeww's Avatar
Alright! Thanks a lot for the help.
marksoftball
Nov 29, 2014 09:27 PM
89Recon
Oct 22, 2011 05:50 PM
Wexinlo
Apr 6, 2011 11:35 PM
fondo
Aug 19, 2009 04:07 PM
Tony H
Jun 14, 2009 10:32 AM
