Driving me crazy. Need help.
I have a '95 Blazer that has had a misfire at idle for a couple years. Now, it's beyond that. If you let it set at idle for more than 3 minutes it acts like it's running a high lift cam. It hits so hard the vehicle shakes!
It drives perfectly fine. I think it's flooding out, due to when it begins it's "race car mode" you can give it throttle and it evens out for a little at idle.
There is a code for the IAC, but has been that way for a long time.
Here's what's strange. Fuel, timing, and compression are all up to par. I performed a leak down test as well, nothing. Pulled the intake twice (once to put a new dizzy in), no leaks noticeable. It has all new ignition components and a recent tune-up. AcDelco fuel pump two years ago. I'm starting to think it may be an egr issue, but never seen an EGR cause something so aggressive. It may also be a computer issue, but it'd be weird to only act up at idle wouldn't it? Injector is really loud as well, but has also been that way for a while.
I'm afraid for the engine. As it is my girlfriend's daily at the moment and she has no idea what to do if it were to get worse.. if it could aside from the engine blowing. Any help or ideas are appreciated.
I used BWD wires, cap, rotor and NGK plugs. AcDelco and BWD are usually the same part. One company makes them and puts them in different boxes, and never had an issue with NGK's. Running the same setup on my 97. Ill post a video in a few on what its doing.
I'm going to change plugs and wires as the distributor is only 6000 miles old, and they have about 20k on them. I hooked my spark tester up, but it's difficult to catch a misfire with that, lol. Here is the video of what it's doing. It has been getting progressively worse over the past couple days. Ignore the turn down exhaust, lol.
https://www.youtube.com/watch?v=UePs...ature=youtu.be
I'd say for one you have an exhaust leak somewhere. I don't know if 95's have O2 sensors, but if they do an exhaust leak could cause O2 sensors to send readings that could cause an improper air fuel mix to the intake.
I didn't mean to put IAC. Lol, I don't know what I was thinking, it was a long day at work I presume. It's a code for the Air Charge sensor. It's been on for a couple years, the connector pushes itself out and every now and then I'll fix it just to get the light to go off.
The exhaust leak is where I had to temporarily put a 4" piece of flexpipe in. Ran out of welding wire, so I just clamped it. The exhaust before had holes all the way down, including one in the muffler. It does have 02 sensors as well.
ws6power1
18
05-15-2010 11:41 PM
johnsgarage1001
03-11-2007 01:27 PM
