Drop in V8
Old Dec 3, 2008 | 07:17 PM
NVANZEE's Avatar
Default Drop in V8
What is the easiest V8 to drop into a 99 2dr blazer. Something with the least amount of mods. Also how much would i be looking at spending out the door not including labor.
Old Dec 3, 2008 | 11:53 PM
vin791's Avatar
vin791 is an unknown quantity at this point
Default RE: Drop in V8
similar year/ fuel delivey type 350 small block.if you have the 4.3 in there its pretty easy. and it depends where you get the 350sb from. you could spend $1500 all the way on up, depending on what power it makes/ how many miles/ aluminum vs. cast iron block, etc.
Old Dec 4, 2008 | 05:16 AM
NVANZEE's Avatar
is there one that will bolt up to my trans
Old Dec 4, 2008 | 07:08 AM
Duntov's Avatar
Banned
Duntov is an unknown quantity at this point
A conversion kit costs about $700 whichincludes a manual, 4WD mounts, 4WD headers, aluminum radiator, 4WD oil pan. You will need to separately purchaseual elec. fan kit, $360; radiator hose, $22; Radiator brackets, $39; Temperature sensor, $36; Fuel pressure regulatorby-pass, $50; Mini starter, $119. Then you must evaluate your transmission and make the determinationif it is up to the task or if it needs to be rebuilt with better parts.
About $1500worth ofmajor conversion parts will get you started after you buy an complete V8 engine. Engine costs can vary from $600 for a used salvage yardmotor to $7,500 for a complete 410 HP Chevrolet ZZ4 350 CIV8 crate engine.To be more practical,you can purchasea well built350 CI V8 street enginefor about$2000 from most high performance engine builders.
Then comes the fun part.
Old Dec 4, 2008 | 07:35 AM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
Check these guys out.
http://www.jagsthatrun.com/Pages/Che..._S-10_V-8.html
yearofthemonkey
Jul 20, 2005 11:53 PM
02 Vortech
Suspension Tech
Jun 23, 2005 03:23 PM
zero psi
Suspension Tech
13
May 24, 2005 05:17 PM
blazin97
Suspension Tech
Dec 13, 2004 12:06 AM
timetoblaze
Sep 28, 2004 08:16 PM
