duraspark conversion swap?
Old Aug 20, 2008 | 02:38 AM
supermar82's Avatar
supermar82 is an unknown quantity at this point
Default duraspark conversion swap?
ok so i bought this ...'91 saturn truck thing my buddies call the "chevurn" it a '91 saturn body on what i was told was a '76 chassis. so according to the guy i bought this monstrosity from there is supposed to be a 4.3 engine in it that has its ignition modified to work like an old carburated engine without the computer hook up. now i had a '84 bronco II that i had swapped out the ingntion system with a mustang II ignition system in wich i eliminated the use of the computer and swapped out the dizzy and changed the ignition coil and added a duraspark box. i am not sure if there is a similar process for the 4.3l engine but according to the guy thats kinda what he did. now this thing is kinda running like crap rite now and i could use some help if anyone gets what im dealing with. heres a pic of my...thing and you gotta admit...this thing is effen weird! i could really use some help here! thanx in advance!
Old Aug 20, 2008 | 06:05 AM
Default RE: duraspark conversion swap?
We are going to need some more information first... Define "running like crap" a bit better. That could mean anything like it just doesn't have much power to it barely wants to stay running.
Old Aug 20, 2008 | 09:33 AM
cliro's Avatar
cliro is an unknown quantity at this point
wheres the picture???
Old Aug 20, 2008 | 12:57 PM
supermar82's Avatar
ORIGINAL: swartlkk
well it definately lacks power but it also sat in one spot for like 10 months the guy said so that could have someting to do with it. also i have to regulate the fuel pressure manualy with a turn valve that has a gauge on it and ive been keeping it at around 6 psi like the guy told me to do. im gonna try to do a simple tune up this weekend and ill let you know if i notice any change. so what happens is that when i step on the gas it wants to bogg out then when i get it up to speed it wont go over like 45. here is a pic of what it looks like:
http://i145.photobucket.com/albums/r...fb704ebba1.jpg
Old Aug 20, 2008 | 01:22 PM
Need some more information on the motor? What has been done to it? We can't see through sheetmetal and a picture may not help... You need to get some numbers off of the carb, intake, distributor, etc.
Bobcat13
Nov 10, 2013 06:03 PM
m5james
29
May 17, 2010 01:00 AM
Blazian
Apr 23, 2007 09:59 AM
AJPal13
Aug 13, 2005 01:22 AM
78blazer
Oct 15, 2004 11:59 PM
