Easiest way to access lower trans cooler line 2000 4wd
Old Apr 27, 2019 | 08:57 AM
trapperpg3200's Avatar
trapperpg3200 is on a distinguished road
Default Easiest way to access lower trans cooler line 2000 4wd
Due to high trans temps, I suspect a clogged trans cooler. I am going to flush the cooler, but I am at a loss
for an access path for the lower cooler line. From the top the radiator hose is in the way. From underneath the
frame rail blocks access. My idea at the moment is to remove the fan shroud and fan, but
was wondering if there is an easier way.
Old Apr 27, 2019 | 10:42 AM
When I last took out my radiator taking out the fan shroud and also the battery and also I think the battery tray to get easy access to the trans cooler lines.
Tajohns34
Aug 17, 2014 04:31 PM
Helter80
Aug 28, 2013 09:35 PM
blazerJim1701
15
Jul 30, 2009 02:28 PM
blazerJim1701
Jul 29, 2009 12:54 PM
DaleA
Jan 7, 2009 06:54 AM
