EGR?
EGR?
Does anyone have pics of where the egr valve is and how to clean anyhting would be a great help
thanks
thanks
RE: EGR?
what year is your blazer? i know the new 4.3 is right in front and you can just take carb cleaner take the egr off and and clean it with that
RE: EGR?
I believe you have an '01 4wd, don't you? The EGR valve is located at the front of the engineto the right ofthe radiatorhose connection.
[IMG]local://upfiles/4800/FDB5E73DB17749209409DA0F9DABDEDB.gif[/IMG]
Disconnect the harness connector and remove the bolts holding the valve to the engine, remove the valve and the gasket.
[ol]Depress the pintle several times using a pencil eraser or other suitable soft instrument. The pintle should move in and out smoothly. Replace the valve if the valve exhibits tendencies to stick.
Try to rotate the EGR valve electrical connector housing. Repeat for the coil housing. Replace the valve if the valve exhibits any looseness.
Inspect the EGR valve pintle and seat for deposits. Use a cloth or other suitable soft device to remove the deposits. Remove all loose particles. Replace the valve if the deposits are such that the pintle to base interface cannot be cleaned adequately to allow the pintle to seal against the seat. Damage to the powdered metal EGR valve base occurs if cleaned with solvents, sharp tools, wire brush or wheel, or sand blasting. Cleaning by these methods is not recommended. [/ol]
Installation is the reverse, use a new gasket.
RE: EGR?
Thanks for the input ill try and let you guys know
yzf125
16
06-18-2007 02:47 PM
blazingsadle
02-04-2006 06:14 PM
khalid_20879
12-28-2005 08:43 PM
