egr tube question
Old Feb 13, 2013 | 09:36 PM
richphotos's Avatar
I would replace it, I think you would take a mileage hit with it blocked, and might have some issues with it running bad. not 100% on that though.
Old Feb 13, 2013 | 09:41 PM
Here are some of the Cons: Among other things, EGR reduces combustion temperature which reduces detonation, (spark knock). Without EGR gasses mixing with inlet air, the engine will have detonation. The knock sensor will detect it and ignition timing will be retarded by the PCM until there is no more knock.... or power.... or fuel mileage. Disconnecting the knock sensor will stop the PCM from retarding ignition timing, BUT, combustion temperatures will rise and the detonation will burn holes in the tops of the pistons. There's a whole string of other things involved, along with an EPA fine if you get caught.
Here are the Pros:
Old Feb 13, 2013 | 09:47 PM
richphotos's Avatar
Here are the Pros:
I laughed super hard when I read the pro's......
But truth there. Its just better to fix it.
Old Feb 14, 2013 | 05:04 AM
swanman35's Avatar
swanman35 is on a distinguished road
Haha alright guys thanks! I figured I would have to anyway.
Old Feb 14, 2013 | 02:39 PM
One thing to always keep in mind when it comes to parts on a vehicle: The manufacturer does not install a single part unless it is absolutely necessary. Whether an engineer prescribed it, or the gubment demanded it. If the gubment demanded it, and you remove it, there is a fine involved.
Old Feb 15, 2013 | 09:11 AM
swanman35's Avatar
I am going to be rplacing it.
kcblazer
Dec 12, 2013 07:31 PM
racsan
Sep 7, 2013 10:01 PM
billfrank85
Apr 16, 2012 09:40 PM
actconstruction
Apr 4, 2010 08:31 PM
bonzo
Nov 30, 2009 09:25 PM
