egr valve
Old Nov 7, 2007 | 05:12 PM
kevss10's Avatar
kevss10 is an unknown quantity at this point
Default egr valve
I put a 1990 350 in my 1991 s10 blazer,All the wiring was correct except for swapping a couple of plugs.The only problem is the egr vacuum plug does not have three wires like the one in the s10,Is it ok to use the egr vaccum from the 4.3 liter?
Old Nov 7, 2007 | 06:49 PM
Default RE: egr valve
Yes, you should be able to use the vacuum solenoid from your old engine. It should perform the same function.
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
BlaziNator
Oct 26, 2009 03:43 PM
yzf125
16
Jun 18, 2007 02:47 PM
khalid_20879
Mar 14, 2006 04:23 AM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
