Egr Valve
Old Mar 7, 2015 | 06:59 PM
Joshuamorrow77's Avatar
Joshuamorrow77 is on a distinguished road
Default Egr Valve
Hi all, just had a quick question for you guys that I can't seem the answer to anywhere. Is there any possibility that a bad egr valve could cause the heat in my 1995 blazer to go into default mode? I'm having a bad idle problem and a hard time starting and an occasional stall, so I figured it's the egr valve already but I'm hoping this is also the vacuum leak I've been looking for that's causing the heat to go into default mode. In advance to this I have a bad input shaft seal that I'm looking at replacing due to the transmission fluid in my vacuum lines. I've also heard that it is the vacuum switch near the transfer case that's the problem there. Can anyone give me some clarification that way if I don't absolutely have to I won't drop the transfer case. Thank you all in advance.
Old Mar 9, 2015 | 07:57 PM
LeWhite's Avatar
EGR is only applied off idle to part throttle. An engine with EGR at idle wont run. An engine with EGR at full throttle wont run well.
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
BlaziNator
Oct 26, 2009 03:43 PM
yzf125
16
Jun 18, 2007 02:47 PM
khalid_20879
Mar 14, 2006 04:23 AM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
