Eng oil in Trans?
Old Apr 9, 2011 | 03:11 PM
duffy47's Avatar
duffy47 is on a distinguished road
Default Eng oil in Trans?
Yesterday I lost almost all drive. Much trans slipping, unpredictable change ups, very high revs (not always though) and ultimately no drive unless I stopped, turned off and reatarted. Even then I could only limp along for a couple of minutes until I lost all drive again. Dropped the trans pan today and it looks like I've got a significant amount of engine oil in there!! The fluid is jet black. Can it really be engine oil contamination, how could that happen? I had a look through the bellhousing inspection plate and all looks good and dry in there. Has anyone experienced anything like this before? Could somthing else lead to black fluid?
Yours confused
Mick
PS its a 98 4.3 Auto 4WD
Old Apr 9, 2011 | 05:22 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
No whats happened is the clutch plates are now in your fluid .
Old Apr 9, 2011 | 05:44 PM
Cidium's Avatar
Cidium is on a distinguished road
I second that, sounds like it's time for a rebuild or replacement.
Old Apr 9, 2011 | 08:51 PM
duffy47's Avatar
130k miles, fluid change 30k ago, pampered car, unbelievable. Any recommendations for a recon at a reasonable price?
Old Apr 9, 2011 | 10:44 PM
TZFBird's Avatar
TZFBird is on a distinguished road
You have a few options ranging from cheap to expencive. There are variations in those depending on how much work you want to do yourself.
1) Find a used transmission that is known to work.
2) Rebuild the transmission yourself.
3) Buy a rebuilt or have yours rebuilt.
Either way the more you attempt to drive, the more damage that will be done.
Old Apr 10, 2011 | 01:13 PM
duffy47's Avatar
I will have a look locally (Dayton OH) but does anyone have any recommendations for a recon supplier? Also any tricks or cathes I should know about to speed the removal and install?
Starter Guy
Dec 13, 2009 08:30 AM
chitowncruiser
Nov 28, 2009 08:03 PM
rick nielsen
Engine & Internal
Oct 14, 2007 03:41 AM
arbowman
14
Jul 9, 2007 07:11 AM
arbowman
Mar 29, 2007 11:46 PM
