Engine balance shaft
Old Dec 16, 2015 | 04:02 AM
newguy's Avatar
Default Engine balance shaft
Does anyone know how to tell if your engine has a balance shaft without tearing it down? Mines a 2000 zr2 4.3
Old Dec 16, 2015 | 09:42 AM
LesMyer's Avatar
It has one - and it's second design. why do you ask?
Old Dec 16, 2015 | 12:52 PM
newguy's Avatar
Comp cam
Old Dec 16, 2015 | 02:38 PM
LesMyer's Avatar
Originally Posted by newguy
Comp cam
I understand.
I recommend these (reuse the balance shaft gears). I degreed my cam and these gears gave correct cam timing straight up.
Amazon.com: Melling BT5452 Timing Chain Tensioner: Automotive Amazon.com: Melling BT5452 Timing Chain Tensioner: Automotive
Amazon.com: Melling 3-8MMSRH72S Timing Chain Set: Automotive Amazon.com: Melling 3-8MMSRH72S Timing Chain Set: Automotive
Old Dec 16, 2015 | 03:39 PM
newguy's Avatar
Thanks
Old Dec 17, 2015 | 09:38 AM
newguy's Avatar
Old Dec 17, 2015 | 12:09 PM
LesMyer's Avatar
Here's the stock cam specs for comparison. Note J604D is valve timing at 0.006 lift (same as Comp cams). However, Comp Cams duration listed is at 0.050.
http://www.federalmogulmp.com/en-US/...-%20CS1572.pdf
So:
ID / IO / IC / EO / EC / Lift / Intake Center / Lobe Separation / Duration (0.050)
Stock / 15 / 63 / 73 / 21 / 0.4144/0.4282 / 106 / 111 / 191/195
56-440-8 / 22 / 58 / 69 / 17 / 0.501/0.501 / 108 / 112 206/210
Old Dec 17, 2015 | 12:41 PM
newguy's Avatar
The guy at comp cam said there would be definate kick in seat increase. Also will bd doing headers and reflash at the same time. Can't wait!!!!
Old Dec 17, 2015 | 01:57 PM
LesMyer's Avatar
Never done it myself on a Vortec V6, but please remember you will:
  • definitely need new adjustable rockers (Comp Cams rockers to fit the Vortec head)
  • probably need better valve springs (with corresponding machining of heads - I know that V8 Vortecs typically need machining or they need some sort of beehive springs to upgrade).
  • probably need valve guides in Vortec heads modified/machined for the much higher lift cam (I know that V8 Vortecs typically need this.
I would definitely talk to Comp Cams before proceeding unless you are already taking the heads off and planning to have this stuff done.
Get HPTuners or EFI Live and flash PCM yourself. Then you can tune at your own discretion, and change in the future. Plus it's a cool thing to get into. Just be sure to save your original tune somewhere safe! I have HPTuners, but only for the diagnostic capability (don't have the tuning upgrade to the software).
For headers be sure to get full length headers.
Good luck and best wishes!
p.s. I have a Comp Cams camshaft in my S10, but 2 more cyl and no fuel injection.
Old Dec 17, 2015 | 03:58 PM
newguy's Avatar
Cody at comp cams said no machining needed and I would need new springs. Was thinking of new rockers ,seals, etc while it's part any ways
piscespokerbrat
Apr 21, 2012 11:58 AM
Chevy33
Nov 28, 2011 08:32 AM
noon_crue
Jul 19, 2009 08:39 PM
4speed
Oct 16, 2008 09:38 PM
brunosrk
Sep 21, 2007 02:58 PM
