engine mountings
engine mountings
Hello!
I tried to change all engine mountings (because they are really bad) on my chevy blazer 1999, 4,3 V6 , 4 wd.
I read that after some basical operations i should just lift up a little bit myengine and I will see the mountings. In special catalog I found that changing ofmountings takes only 2 or3hours. But I dont believe that it`s posible to take offengine with the transmissionand put them backfor only two or three hours.In any case, it`s not so easy as read.
Maybe somebody know how to do that (to change engine mountings)?
Maybe, I should do some special operations ... because now, I just lock on my engine and i dont know what to do.
Please, write how to do it step-by-step.
Thanks for all!
Thanks for all!
RE: engine mountings
I change em one side at a time, just loosen up on the tranny mount bolt on the tranny x-member and you should gain the clearance you need.
N.alaska_blazer
02-23-2009 01:31 PM
Tony H
12-14-2008 02:04 AM
loppy crimp
09-11-2008 08:31 PM
DBlaser_ca
08-02-2007 04:44 PM
