Engine not as responsive as it used to be
Old Apr 23, 2009 | 03:41 PM
tubgrinder1968's Avatar
tubgrinder1968 is on a distinguished road
Default Engine not as responsive as it used to be
i have a stock 1988 blazer 4x4 with 4.3 V6 fuel injection automatic. Its not as responsive when I give it gas anymore and it runs a lot quieter at an idle. Is there anything that can be done besides exhaust to bring it back up to speed.
Old Apr 23, 2009 | 04:36 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
an exhaust wont bring it back to life, trying doing a tune up, changing the oil, fuel filter and run a can of sea foam through and also change the air filter then you should be good.
Old Apr 23, 2009 | 09:24 PM
alright sounds good. I was scratchin my head because it used to run like a charm and had that good "roar" now the past week or so it seems like a different car
Old Apr 23, 2009 | 10:20 PM
okvortec's Avatar
Does that seafoam stuff really work?
Old Apr 23, 2009 | 11:55 PM
mikeinwi's Avatar
alot of guys swear by it, if you do a quick search youll be able to find the steps on how to use it and a ton of testimonials from guys.
Buddykitchen
Dec 10, 2016 06:37 PM
Crunch
Apr 28, 2012 02:21 PM
butters
May 15, 2009 08:06 PM
tolleyc
Jul 29, 2007 05:57 PM
