Engine stalling
Old Jan 26, 2008 | 08:28 AM
WVblazer's Avatar
WVblazer is an unknown quantity at this point
Default Engine stalling
Hello People I'm new to the forum, I was wondering if anyone has had the same problem as me with their 99' Blazer 4x4, the engine stalled out while parked, the engine was warmed up and started straight back up then it stalled again while driving along again it started right back up I thought it could be water in the gas so I put some dry gas in and filled up from a different gas station with higher octane gas but it started to stall more often until it was stalling every couple of miles and got harder to start, now it won't start without a lot of trys and stalls witin a few minutes, I can hear the fuel pump start when I switch on the key and gas is coming through when I push in the valve it squrts gas, I took the battery off over night to reset the computer (and that fixed my 4WD!) but it's still the same, any Ideas?? anyone had this problem? Iv'e been told by fuel pump is the problem but I can hear it pumping so I don't know.
Old Jan 26, 2008 | 08:33 AM
rriddle3's Avatar
Default RE: Engine stalling
To rule out the fuel pump and pressure regulator, you will have to test them. Connect a pressure gauge to the schraeder valve on the fuel inlet line and turn the key to 'on'. The pressure should read 55-62psi. Turn off the key and the pressure should drop no more than ~2-3psi. Let us know what you find. Oh, and [sm=welcomesign.gif]to the Forum.
Old Jan 26, 2008 | 05:34 PM
thegr81's Avatar
I am thinking a fpr problem but do the test suggested and see were your at with psi then we can move forward with other troubleshooting! Also welcome to the forum, glad to have you!!!
wcook369
Dec 21, 2010 02:54 PM
jsleeper81
Sep 28, 2010 04:27 PM
murray32x
Sep 23, 2010 03:11 PM
matrixgk17
Jun 23, 2010 02:27 PM
Always Something
Jun 26, 2008 10:03 AM
