Engine swap cranks but doesn't start
Old Apr 10, 2022 | 04:16 PM
Moffitt_Farms's Avatar
Moffitt_Farms is on a distinguished road
12.3, new battery just cranked on.
Old Apr 10, 2022 | 04:35 PM
GeorgeLG's Avatar
I assume you mean 12.3v with the ignition on.if so then you either have a bad pump or a wiring problem from the pump relay to the pump or the pump ground. Either way the tank has to be dropped to either fix the wiring and or to replace the pump. Once the tank is dropped we need to backprobe power and ground with the pump still connected and see what the net voltage is at the pump during the key on priming cycle.
George
Old Apr 10, 2022 | 05:09 PM
On a side note the guy gauge sometimes reads full next second empty and vice versa. Are these 2 problems connected?
Old Apr 10, 2022 | 05:14 PM
GeorgeLG's Avatar
That just confirms that you have either a failing pump and or a wiring problem. I keep adding wiring because many an expensive replacement pump has been installed only to still have the problem and then find out that the solution is a $0.10 piece of wire. This is a strong possibility for you because of the physical trauma of the engine swap and its always a possibility in a 20 year old truck.
The gas gauge sending unit and fuel pump are part of the same assembly. We can check the sender wiring while you have the tank dropped.
George
Old Apr 14, 2022 | 01:22 PM
Just now getting back to this, been raining and I am working on it outside.
My help is a little rough and broke a plastic nipple on the fuel pump so it has to be replaced.
How do I go about checking the wiring?
Looks like he got this piece too, what is it called?
A1 Handyy
May 27, 2014 04:40 AM
Bluechevyblazer
Feb 6, 2011 10:57 AM
gionet331
Dec 9, 2010 07:32 PM
jamel
Sep 24, 2009 08:36 AM
metalhead
Jun 5, 2009 02:02 PM
