Engine Ticking
Old Jul 23, 2013 | 08:51 PM
smaiwald's Avatar
smaiwald is on a distinguished road
Originally Posted by chris015
Sure its not the pcv valve ticking? which is normal.
It could be. How would I check that?
Old Jul 24, 2013 | 12:26 AM
richphotos's Avatar
are you able to pinpoint which side of the engine the ticking is coming from?
Old Jul 24, 2013 | 07:07 AM
smaiwald's Avatar
I've tried to but its difficult because i cant reproduce it in the parking lot. It only ticks when I'm moving. It seems like its coming from the left side but I can't be certain
Old Jul 24, 2013 | 07:30 AM
As stated, check for PCV valve noise. More specifically, check to see if the throttle/cruise cables are resting against or are even just close to the vacuum line that runs to the PCV valve in the driver side valve cover. Sometimes with an older vehicle, the motor mounts can have a bit more movement to them and it can cause these cables to come in contact with each other which will allow the noise from the PCV valve to be transmitted to the firewall where it is somewhat amplified. Typically the noise just blends in with the rest of the engine noises.
alfred1254
Jan 11, 2010 02:01 PM
willtoskie
Jan 10, 2010 04:56 PM
coffeehound5150
Oct 3, 2008 05:56 PM
Jharper
Dec 12, 2007 06:00 PM
low
Jun 25, 2005 04:52 AM
