Engine Ticking NEED HELP!
Old May 4, 2012 | 11:25 PM
red06sc's Avatar
red06sc is on a distinguished road
Kinda reminds me of my problem. Only difference is mine is very random. So random that i cant track the noise down. https://blazerforum.com/forum/2nd-ge...-lifter-61135/
Old May 27, 2012 | 12:16 AM
94tahoe95lt's Avatar
94tahoe95lt is on a distinguished road
still in the process of piecing my blazer back together however I have come to the conclusion that the problem may have been a stretched out timing chain which when pulled apart my chain was extremely loose dont have truck fully together yet but that may have been my problem once I drive it ill let you all know if that fixed my problem
Old Jun 3, 2012 | 02:54 AM
well installed the new timing chain and gear and still same problem will still update on what the REAL issue is if I don't give up and sell the truck.
Old Jun 3, 2012 | 03:05 AM
red06sc's Avatar
did u replace the lifters?
Old Jun 10, 2012 | 02:49 PM
evomat's Avatar
evomat is on a distinguished road
ive done all the above except timing chain.new lifters,new distrbuter (on way) .checked EGR.it rattles. new intake gaskets etc ...check timing ( a timing light will not work). have to hook up to a computer to check and adjust or get lucky and loosen dist. and try doing a manual adjustment. i have read on here that it can be done . look under diagnostic codes P1345. have not tried the spark plugs but i will
Old Aug 9, 2013 | 02:56 AM
Thought I would finally give an update it was a lower engine noise probably a spun bearing didn't have time to repair or replace the engine nor could I afford to have someone do it for me so I sold the truck thanks for the help.
bobomojo
Jun 16, 2014 01:03 PM
alfred1254
Jan 11, 2010 02:01 PM
willtoskie
Jan 10, 2010 04:56 PM
Jharper
Dec 12, 2007 06:00 PM
low
Jun 25, 2005 04:52 AM
