Engine Ticking - Which oil should i use?
Old Feb 9, 2010 | 03:30 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
Default Engine Ticking - Which oil should i use?
I have a 98 4.3 blazer and latley (cold months) i will get a slight tick when i first start the truck up. if i give it a lil gas it goes away in about 10 seconds like one of the lifters is being pumped up. all the lifters were replaced when i did the intake gasket back in august. About 2k sence the last oil change. currently running 10W-30 synthetic. Im going to do an oil change next week so i was wondering, should use thicker oil ( 10W-40) or thinner oil (5W-30) in the winter months? also what brand of oil / filter have you guys had good luck with?
Old Feb 9, 2010 | 05:27 PM
1998ZR2's Avatar
1998ZR2 is on a distinguished road
i like Castrol, lately Ive been using 4 quarts of oil and a 1/2 quart of Lucas Synthetic Oil Stabilizer. It worked great at cold starts. I use ACDelco oil filter PF52.
Old Mar 28, 2010 | 09:47 AM
MrBill99's Avatar
MrBill99 is on a distinguished road
Default Valve noise on start
It might be a problem with the anti-drainback valve on the oil filter that you were using...check out my post here:
https://blazerforum.com/forum/showth...ght=oil+filter
Hope this helps!
MrBill99
Old Mar 28, 2010 | 11:11 AM
SuperBock's Avatar
SuperBock is on a distinguished road
GM specs call for 5-30.
Old Mar 28, 2010 | 02:01 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
thinner oil is better for cold weather anyways.
Old Nov 10, 2010 | 07:29 AM
blazer7630's Avatar
blazer7630 is an unknown quantity at this point
this post is a little old and figured I would add to this since it is getting cold again, but I get that same tick at start-up if I use a regular oil. I tried high mileage oils but none of them seemed to fix this problem. The solution to your problem is to run Castrol 30 weight oil and it will get rid of the ticking for good. The lifters arent getting enough oil, seems to be a common problem for these engines and it just needs a thicker oil to keep it lubricated. I've been running 30 weight since 80K miles and have not had any troubles out of it. My engine still runs strong and I never get that ticking on very cold start ups. If you go back to a regular oil after using the 30 weight and do a cold start up the ticking will come back.
jonesar22
Jun 12, 2014 11:50 AM
Brian26
Sep 19, 2012 04:24 PM
Klturi421
Jun 16, 2012 12:00 PM
southernsteel87
Nov 6, 2010 05:02 PM
Shalom
Apr 16, 2010 10:10 PM
