Engine Vibration
Old Jul 16, 2010 | 12:47 PM
inkedallover55's Avatar
inkedallover55 is on a distinguished road
Default Engine Vibration
I have a 96 blazer that has a heavy vibration when idling in drive, especially with the A/C on. I have changed the EGR valve, plugs and wires. Any ideas of what this can be? Reverse is fine, nuetral is fine, park is fine. Only the drive gears make the engine vibrate at stop signs and stop lights. Worse with the A/C on. Thank you in advance for any information.
Old Jul 16, 2010 | 01:09 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
If its not doing it in any other gear , have you had your tarnsmission checked yet? I wonder if it could be the lock up in the torque converter.. If you put it in drive and start to power brake it what happens? you know what power braking is right? ive actually had people stare at me like i had three heads when i said that to them..like a deer in the headlights..
Old Jul 16, 2010 | 08:34 PM
Default engine vibration
it is worse with the A/C on. Not sure if this is transmission related.
farley463
Jan 29, 2014 04:51 PM
psewell@gvtc.com
Dec 8, 2009 08:48 PM
mattbbb14
Mar 23, 2006 09:46 PM
cthomson
Sep 7, 2005 04:51 PM
blazzinblazer1998
Feb 16, 2005 04:41 AM
