Engine will not heat up.
Old Dec 9, 2008 | 06:33 AM
  #31
salvy's Avatar
salvy is an unknown quantity at this point
Default RE: Engine will not heat up.
Okay, Let's rule out a leaking intake gasket, they canleakever so slightly (like mine did)Go rent a radiator pressure tester, bring it up to about 14-15 #'s, watch it carefully, it should hold there for quite a while. If it stays you should be ok, If it drops, there's your problem, it's so common for these to leak. (& this will allow air in the system )
When I recommended you bleeding the air, you didn't mention having the idle up to about 1500-2000 rpms steady for about 1/2hr. That will move any stubborn air pockets in the system, so it will rise to the top of the system and escape.
I had no luck moving the air on mine @ idle/cool sequence. So I forced circulation of coolant around engine, and little bubbles of air kept coming to the top for over 20-25 minutes !Then the problem was resolved. Mine is perfect now,finally !
Old Dec 14, 2008 | 09:57 PM
  #32
hbnr86's Avatar
hbnr86 is an unknown quantity at this point
FINALLY!!! I have heat, i was able to get to a place with a garden hose to flush the heater core this weekend. When i flushed it the normal direction of flow everything looked normal, then i back flushed and WOW i couldnt believe how dark and chunky the water was that came out.
Now i have really hot heat, temperature gauge still does weird things, but oh well.
Old Dec 15, 2008 | 07:42 PM
  #33
gscrippler's Avatar
gscrippler is an unknown quantity at this point
did you replace the thermostat with a 195 degree rated one or the 160 that is available for it. that may also be the problem
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
JSBlenz9498
Nov 18, 2009 10:05 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
