Engines that Can be Used in 1998 Blazer?
Old 03-08-2021, 09:49 PM
LesMyer's Avatar
LesMyer will become famous soon enough
Originally Posted by dgriffinhere
i am having a hard time finding a 98 or 99 4.3 for my blazer. plenty of 4.3s out there, but are used up......i have a 98 blazer built in 02/98 and would like to know what is the latest model engine i can use in this truck??? thank you again for your time and info.....david g.
You can use from a 1996 up to a 2004 motor, but for 2001 and up you will need to adapt your knock sensor mounting in the block to the old style, using an adapter. The threaded hole is different size. You cannot use the late style knock sensor, so don't even think about it! Also, you may need to use your intake and exhaust manifolds on a later motor. Otherwise no problem.
Old 03-08-2021, 09:56 PM
dgriffinhere's Avatar
dgriffinhere is on a distinguished road
THANK YOU--THANK YOU--that opens up a whole new world of possibilities......you are da man........thank you again......bought an engine puller today...so im gettin there.......sincerely david griffin
Old 03-08-2021, 11:11 PM
i just found a 2000 olds bravada engine vin w with good miles on it and want to make sure that my 98 4wd blazer vin w oil pan would fit if i need to use it. looking at the pics, the engine looks exactly as my 98 engine but i cant see the oil pan. dont know if the donor car is 4wd or not. just wanted your opinion!!! thank you soooo much and i am going to stop bothering you pretty soon.....i promise.....thank you david griffin
Old 03-09-2021, 06:37 AM
LesMyer's Avatar
It will fit if you need to use it. If it is from a 2WD going into 4WD, be aware that sumps (pickup tubes) are also different. It's no bother.
Old 03-09-2021, 08:29 AM
Default Good news
Ok brother. That's what I needed to know. I'm going to make an offer on that engine...again--.THANK YOU! ! David g.
Old 03-09-2021, 05:11 PM
well hells bells.....i ordered a 2000 4.3 vin w for my 98 blazer vin w and they said that a 2000 4.3 would only work in a 2000 model year....this company has a reman service on site and the block numbers are different and show only compatible for 2000 model blazers, astros,bravada, etc. they will not sell me the engine, so im back to where i started still saying what to do...whats the difference in the blocks that will cause it not to work?? somebody shoot me,,,please.
Old 03-10-2021, 11:04 AM
LesMyer's Avatar
AFAIK there is no difference in the blocks that will cause a 2000 engine to not work in a 1998. Who cares which type of rockers it has. Makes no functional difference. As I said, you may need to use your exhaust and intake manifolds from your 1998. Only difference in the block throughout these years I am aware of is the knock sensor mounting hole size changed. I suppose there could be a partial year changeover of the knock sensor in 2000 or 2001. All you need to do is identify which knock sensor is on the engine. You need one with a single wire connector.
Look at GM Goodwrench replacement engines
12491865 goes into 1996-1998 (Ball pivot rockers and single wire knock sensor)
12491867 goes into 1999-2000 (roller rockers and single wire knock sensor)
12491869 goes into 2001-2002 (roller rockers and 2-wire knock sensor)
Have you considered one of these? 3 year/100K warranty. GM Goodwrench Rebuilts. I haveone - about 50K so far. From Jegs = no core, free shipping. They even give you both sumps and the front timing cover.
https://www.jegs.com/p/Chevrolet-Per...08163/10002/-1
Old 03-10-2021, 11:23 AM
LesMyer's Avatar
early knock sensor 1996-2000
https://shop.advanceautoparts.com/c4...17220751574833
later knock sensor 2001+
https://shop.advanceautoparts.com/c4/knock-sensor/-49998132?term=knock%20sensor&vehicleIdSearch=22592 34&beginIndex=0&sortBy=5&_r=0.875649581186147
These mount in the top of block near the distributor hole.
Almost forgot to tell you. No matter what you buy, make sure to replace the radiator (oil cooler) and flush out the oil cooler lines and oil filter adapter. You don't want any metal from the old engine oil getting into your new one.
Old 03-10-2021, 11:58 AM
LesMyer's Avatar
I changed the thread topic to an appropriate title so others can understand what is being discussed in this thread and closed the other one that you started. No sense in someone else repeating the same info in another thread. You should be able to edit titles as well, under edit/advanced for the first post.
Old 03-10-2021, 09:19 PM
Default Engines that can be used in 1998 blazer
GOT IT!!! WIL ORDER THE 2000 engine in the morning...already have all new gaskets and oil filter lines and new starter ready to go. I WILL SEND A PHOTO WHEN FINISHED....THANK YOU FOR ALL YOU DO!!! DAVID G.
go chevy
10-02-2020 07:42 PM
Dynosoar
12-27-2014 01:46 PM
BillB1210
01-14-2012 10:20 AM
Corrupt
10-31-2009 10:59 PM
98blazer12
01-21-2007 12:50 AM
Quick Reply: Engines that Can be Used in 1998 Blazer?
