Which engines are compatible with mine?
Old Oct 18, 2013 | 12:58 PM
Bobcat13's Avatar
Bobcat13 is on a distinguished road
Default Which engines are compatible with mine?
I have a '97 Blazer LT 4x4 with the 4.3L with 240,000 miles. I discovered today that the intake is leaking coolant down the engine block. They gave me a quote of about $500 to replace the intake gasket parts and labor. I was thinking it'd be a little more practical to just drop a younger 4.3 in seeing this one has 240K miles already. I was wondering
Old Oct 18, 2013 | 12:59 PM
Bobcat13's Avatar
I was wondering which makes, models, and years of GM vehicles would have engines compatible with mine?
Old Oct 18, 2013 | 03:17 PM
rexazz2's Avatar
your pretty much stuck with Blazer , Jimmy ,s10 ,Astro and 1/2 ton P/U
If you google engine code
it should give you the knowledge to match from vin #
http://www.angelfire.com/ca/TORONTO/VIN/chevrolet.html
Old Oct 29, 2013 | 02:34 PM
Katmandu's Avatar
Katmandu is on a distinguished road
I have a 99 S10 Blazer that spun a rod bearing. I had a 4.3 out of 2006 Silverado installed.
The ONLY difference was the knock sensor BOSS (hole). The 2006 knock sensor boss must be tapped to accept the 1999 knock sensor threads.
Absolutely no other issues and or problems.
Old Oct 29, 2013 | 03:52 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
Wow a 2006 in a 99 that's the first time I ever heard of that compatibility as many times as this subject has been discussed.You didn't have to change the pcm?All the other info I have read says only up to 2000 would work with some minor mods and pcm change.
Old Oct 29, 2013 | 06:20 PM
Katmandu's Avatar
I used a 2006 long block (heads+short block) only. No need to swap PCMs whatsoever.
I simply had my intake and fuel injection setup installed on the 2006 long block. No biggie.
Like I stated before, only the knock sensor boss needed to be tapped out. Again, no big deal.
Old Oct 29, 2013 | 06:34 PM
racsan's Avatar
racsan is on a distinguished road
Heck, its only about $35 for a intake gasket kit.(without valve cover gaskets) id much rather spend a few hours changing a gasket than the whole weekend (or more) changing a entire engine....and on that note, i changed a engine on a '96 and shortly afterwards needed a intake gasket due to a coolant leak-go figure!
Old Nov 2, 2013 | 11:06 AM
Question
Were you able to use the new style fuel injectors or not?
Old Nov 2, 2013 | 11:45 PM
Katmandu's Avatar
We simply reused all the 99's FI and Intake setup on top of the 2006's long block. Nothing else.
Bobcat13
Nov 7, 2013 07:08 AM
instygator
Feb 22, 2009 06:59 PM
MDTjettaguy
Oct 22, 2006 09:10 PM
94Blaze
Headers, Intake, & Exhaust
Nov 2, 2004 07:25 PM
Baged96Blazer
Suspension Tech
Oct 30, 2004 09:13 PM
