Exhaust leak or stuck lifter?
Old Aug 26, 2007 | 08:17 AM
jcoop711's Avatar
jcoop711 is an unknown quantity at this point
Default Exhaust leak or stuck lifter?
Exhaust leak or stuck lifter? When I started my 2000 Chevy blazer ZR2 (111000 miles) the other night when leaving work it sounded like it had an exhaust leak. After the engine warmed up the noise went away. Since then every time I start my blazer (when the moter is cold) the same problem occurs. Could an exhaust leak do this or would it be a lifter or something else. There seems to be no loss of power. Any suggestions? Any additives or something that I can add to fix if it’s a stuck lifter? Thanks for any help.
Old Aug 26, 2007 | 04:48 PM
Default RE: Exhaust leak or stuck lifter?
I would say that you should be able to use a mechanics stethoscope to pinpoint the location of the noise. If it's coming from the valve cover it's a lifter not pumping up properly. If you find it down at the exhaust manifold, then you've got an exhaust leak.
Old Aug 27, 2007 | 12:42 PM
Hanr3's Avatar
Buy a can or two of SeaFoam to hopefully free up a sticky lifter.
phatso_99blaz
Headers, Intake, & Exhaust
Apr 8, 2013 03:16 PM
mudnsno
Nov 15, 2009 05:38 PM
Chevyguy032
Nov 26, 2006 04:26 PM
Bob E.
Mar 31, 2006 11:39 AM
glenmoore670
Feb 15, 2006 11:08 PM
