External oil filter lines
Are the external lines one complete assembly from the engine to the filter and then the cooler or are they separate? If separate which line is more common to leak? I'm trying to order the lines from my parts supplier but unfortunately his diagram isn't quite clear on which part I might need.
Ok my parts dealer shows a "oil filter hose" with two lines and two connections on each end and then he also shows a "oil cooler pipe" with two lines with a double connection on one end and two separate connections on the other end which I'm assuming is for the radiator.
I've gone ahead and ordered the oil filter hose as it was the more expensive of the two ($67).
subarugt06
Mar 6, 2011 11:21 AM
ethan.zick
Mar 16, 2010 12:43 AM
vassago41301
Jan 26, 2007 03:58 AM
