failed EGR valve or blockage of pintle
Old Jun 19, 2012 | 10:38 PM
cody10's Avatar
cody10 is an unknown quantity at this point
Default failed EGR valve or blockage of pintle
yesterday my check engine light came on so i got it diagnosed and it was a failed EGR valve or blockage of pintle so i got a new valve and cleaner for the manifold i replaced it and sprayed the cleaner into the manifold, the check engine light turned off for about 10-15 minutes before it came back on. both times the code was p1404 can anyone help me out? i changed my fuel pump the other day could that have any affect? i have a 98 blazer 4 door 4x4
Old Jun 20, 2012 | 06:32 AM
rriddle3's Avatar
See if this thread helps:
P1404 Explained
Old Jun 20, 2012 | 08:37 AM
If the EGR supply tube is really crusted, it often will take using a REALLY long brass pipe cleaner to get the tube itself cleaned out before installing the new valve.
Also, if you didn't use the screened gasket, then you likely have a chunk of carbon in there already again.
96jimmyslt4x4
Oct 2, 2011 05:37 PM
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
BlaziNator
Oct 26, 2009 03:43 PM
yzf125
16
Jun 18, 2007 02:47 PM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
